They might fuss a bit about "proper placement" of the heat sensor and low static pressure would be my guess...which with ducts that size, you basically wont have any static pressure...I have the same issue...but that can be worked around...
Yep. Currently awaiting a response to email. I am wanting to get all the info I can before pulling the trigger and spending the money on the unit, but it is looking like the Drolet HP will be the path I take.Safe bet would be to call Drolet and ask them. FWIW if had that set up I would do it the same way, slip the HeatPro right under that existing hot side duct work. Be sure to hook up the cold air return so you are not drawing from a cold concrete floor.
I'm pretty green when it comes to HVAC. Could you explain the static pressure and what you did to work around d it?They might fuss a bit about "proper placement" of the heat sensor and low static pressure would be my guess...which with ducts that size, you basically wont have any static pressure...I have the same issue...but that can be worked around...
next would be all the questions about operation....![]()
I am not sure I'm following you there.T1 did not use a plenum...but we seen how well that worked out!![]()
It didn't use a plenum and SBI said that was part of the overheat/cracking issue...I am not sure I'm following you there.
Really, I thought it was similar to the Caddy where you had to build your own or have one built.It didn't use a plenum and SBI said that was part of the overheat/cracking issue...
Well, they responded that the plenum is necessary as that is how the unit was tested and approved to function. Then tried to push a Caddy on me which won't happen in that price range.
I can understand a blanket statement of saying it is necessary, I just don't understand why. Why can't it just require a minimum square inch and static pressure regardless of ducting? Really complicates my install as my current setup is also my supply for my A/C
Nope, they had the (2) 8" pipes coming off the top, remember?Really, I thought it was similar to the Caddy where you had to build your own or have one built.
Yeah they don't have the lifetime warranty on the firebox like they used to...T1 cured that!You will also find the warranty on those items will be pretty short anyway.
This is my line of thought too. My current setup has a manual damper which I restrict some flow to the upstairs when heating and remove when cooling.Well I guess we could have predicted that response from the manufacturer. I myself would still do it, but bottom line if there would be a warranty issue and they see the supplied plenum was not used they have an easy out. Typical of most all manufacturers these days.
They do list in the manual the minimum number of 6" take offs that must be connected to other duct work or run to supply registers- I would think that as long as you don't restrict below that minimum you won't have a problem and I don't see that issue with your existing duct work, if anything it might have too much flow and require restricting some dampers at registers to achieve some static pressure. If the Heatpro has a temperature probe in the plenum, they might also be concerned with improper placement of that in a customer supplied plenum as well.
The max caddy is sold through dealers - I am guessing they allow more custom installs due to dealer support / pro installers to oversee these details vs the "big box store" or online marketed Tundra and HeatPro furnaces.
Bottom line - how much do you depend on warranties? Myself for a fairly simple appliance like a wood furnace - don't care about the warranty and will never need to use it. If a damper motor, blower motor, control board fails they will probably still cover that as long as you don't give them the ammo they need so they can say " oh you didn't use the factory supplied plenum - no warranty for you". You will also find the warranty on those items will be pretty short anyway.
would think HO ins would like a new, safer, more efficient unit than that old tank in there now I was using.Yeah they don't have the lifetime warranty on the firebox like they used to...T1 cured that!
I'm like @3fordasho , I'd do it anyways, just make it as "right" as possible so that there's no issues...gotta get it past the HO ins. then too...
Yes, that's true...but since you are switching it out they will want to make sure all the modern standards/codes are met too...looks like you shouldn't have much trouble with that since its not too close to anything...would think HO ins would like a new, safer, more efficient unit than that old tank in there now I was using.![]()
Ohhhhhh, you are right. I forgot about that.Nope, they had the (2) 8" pipes coming off the top, remember?
Right but no real info on it in the manual for us US folk. Is it to be assumed it is all good?That's just in Canada I think...
I am sure they were quoting you MSRP prices. When I bought my Caddy, I paid a lot less than MSRP. Going through a mom and pop dealer and paying in greenbacks also helps in the price department.Well, they responded that the plenum is necessary as that is how the unit was tested and approved to function. Then tried to push a Caddy on me which won't happen in that price range.
Parallel is legal in the states...Right but no real info on it in the manual for us US folk. Is it to be assumed it is all good?
