I finally wrapped up the firewood drying test I had been running for a little over a year. I had posted some preliminary results in other threads but brought this to its conclusion by oven-drying the test pieces and replotting the results according to MC.
Just to recap, I used smallish pieces to speed up the process. I used freshly bucked and split red oak heartwood and tried to keep the pieces as uniform as possible. I cut eight pieces altogether, four large (those numbered "1" on the charts, about 2-1/4" X 3" X 4-1/2") and four small (those numbered "2" on the chart, about 1-1/8" X 2" X 4-1/2"). I placed one large and one small piece in each of four locations: A = a wood bin in a heated indoor living space; B = an unheated but closed garage; C = the top of a covered outdoor firewood rack; and D = the top of an uncovered outdoor firewood rack. Starting MC was too high for my meter but I later calculated it as 73%. I normalized the results to account for slight differences in weight between each group of sample pieces.
Bottom line, I found that the indoor pieces dried the fastest overall. The uncovered outdoor pieces dried fastest in the first couple of days but then maintained a higher MC over the long term (and they ended up looking the most weathered, which was deceptive because they were actually the least "seasoned"). The garage pieces dried more quickly than I would have expected. And even thought the pieces were all about the same length, the narrower ones dried faster...demonstrating that a lot of drying takes place across the grain, not just along it (which I think was a topic of discussion a while back).
The results are shown below.The final MC ranged from about 8% indoors to 15% for the uncovered outdoor wood. There's a lot of variation with the uncovered outdoor pieces because they would get rained on, but even the protected pieces fluctuated slightly as the humidity changed. And finally, the lines converge at the end because I brought them all indoors for a month or so before the final oven drying.
![[Hearth.com] Drying test results are in... [Hearth.com] Drying test results are in...](https://www.hearth.com/talk/data/attachments/197/197187-02cbc19394add2f66b7b27c49ea1d46b.jpg?hash=AsvBk5St0v)
![[Hearth.com] Drying test results are in... [Hearth.com] Drying test results are in...](https://www.hearth.com/talk/data/attachments/197/197209-c285eaba5b43a0f4a00b8c6ac0633d16.jpg?hash=m7gq0DB5iF)
![[Hearth.com] Drying test results are in... [Hearth.com] Drying test results are in...](https://www.hearth.com/talk/data/attachments/197/197233-53d3c65c2ecc356e425d5e2a28246936.jpg?hash=9o-58e_VfH)
![[Hearth.com] Drying test results are in... [Hearth.com] Drying test results are in...](https://www.hearth.com/talk/data/attachments/197/197246-e59b94632db2d6f6f4b83c53888a91fb.jpg?hash=5ZuUYy2y1v)
I was more surprised at how well the garaged wood did, considering that it's unheated out there and there's really no air circulation. Maybe it gets enough heat from the house to make a small difference? And I certainly learned the value of top cover for faster drying.
