Backwoods Savage said:Fred, you are right on about that splitter. Horizontal means just too darned much work; I'd rather split by hand than to do that. Vertical and it is very easy. As you do more you'll even get faster without even trying. As to the tonage, that 27 ton machine should really do the trick, however, you really do not need that much splitting power. You can get a 20 or 22 ton for a lot less dollars and it will split all you need. Ours is a 20 ton that we've had for quite a while now and it has split a lot of wood. We've split for others besides our own. In all the time we've had it, we've had exactly one piece that didn't split. Probably I could have if I'd tried several spots. It just wasn't worth it to me. I threw it on the brush pile to be burned.
Fine, if you can have your wife bring you the rounds. Staging the rounds requires bending. Sitting requires bending and reaching. Wiggling the rounds into position is as much work or more than lifting up onto a horizontal beam. My shoulders and back won't tolerate it.Backwoods Savage said:For the life of me I can not understand why vertical splitting means more bending!
LLigetfa said:Fine, if you can have your wife bring you the rounds. Staging the rounds requires bending. Sitting requires bending and reaching. Wiggling the rounds into position is as much work or more than lifting up onto a horizontal beam. My shoulders and back won't tolerate it.Backwoods Savage said:For the life of me I can not understand why vertical splitting means more bending!
I think I can count on the fingers of one hand how often I've use vertical mode. I much prefer horizontal. To each his/her own.
LLigetfa said:Lastly, my father would kick my butt if he saw me working sitting down if he were still alive. He'd say if splitters were meant to be operated sitting down they would have built them with a seat like a tractor.
LLigetfa said:Maybe you should rig up a foot pedal on that splitter.
