The GFCI trip limit is a fixed value, just a few milliamperes, and not proportional to load or device rating. So one issue seen by folks who had the GFCI breakers that used to be more popular before GFCI receptacles, or with poorly-implemented circuits (too many appliances on one GFCI controller), is random trips. I used to have this problem at my own house, with many Christmas light strings on one circuit, even in dry weather.
Then there are also issues with poorly insulated old power tools and things like antique vent fans, designed in the pre-GFCI era. The easy solution is to replace them, but some folks want to resist.
A thoughtfully-laid out GFCI system, using master and slave outlets in adjacent or nearby pairs can work very well, and should not cause any issues.
Unfortunately, I haven’t read NEC with respect to vent fans. If mine were tripping a GFCI breaker, and it were an older unit, my first step would be to replace it with something modern. If that did not resolve the issue, I would be looking to either run a dedicated circuit to the fan, or at the code compliance options for running it off an immediately-upstream GFCI receptacle. Due to the fixed limit I mention at the top of this post, the more wiring and devices you have on a single GFCI controller (i.e. breaker or receptacle), the more likely you are to see undesired trips.
![[Hearth.com] dumb question on Romex [Hearth.com] dumb question on Romex](https://www.hearth.com/talk/data/attachments/246/246424-9f560fc614c3ebcf91fce4dd080f535c.jpg?hash=gbS6iAvSgG)
![[Hearth.com] dumb question on Romex [Hearth.com] dumb question on Romex](https://www.hearth.com/talk/data/attachments/246/246423-67c5c8c62a13341cbcd1926f8d055af8.jpg?hash=kFmiFJm_Mn)
![[Hearth.com] dumb question on Romex [Hearth.com] dumb question on Romex](https://www.hearth.com/talk/data/attachments/246/246425-87d8a312cea0cd061955c461c6f5d4f8.jpg?hash=RUTdtBzH1E)
![[Hearth.com] dumb question on Romex [Hearth.com] dumb question on Romex](https://www.hearth.com/talk/data/attachments/246/246426-a44ec3c94cc35ad398199a535f8815a4.jpg?hash=0lTqZHYt2J)
