humpin iron said:WRONG Kaowool insulation should be used, how is the flex connected to the ridged??????? I don't see a connector and it looks like its been wrapped with foil tape
Konrad said:humpin iron said:WRONG Kaowool insulation should be used, how is the flex connected to the ridged??????? I don't see a connector and it looks like its been wrapped with foil tape
I appreciate the caps lock, but is kiln paper really necessary? Fiberglass doesn't burn and won't melt until >1500. Rockwool is >2000. Neither of which are temperatures I would even subject to the current 50 year old brick chimney to.
The s/s straight piece is custom made to fit snugly around the flex and is attached with some stainless steel screws where the pipe exits the brick chimney. The tape is 3M flue tape. The DuraFlex litature doesn't mention anything about sealants. I thought the s/s band connections to the t-cleanout were inferior to the snug s/s screw connection I made on the far end at any rate.
