I recently bought a house, with what I was told was an all Duravent chimney system from the stove up through the roof. I needed to add more draft, so I ordered this piece to add 3 FT to the chimney last season.
DuraVent-6DT-36SS
https://www.walmart.com/ip/DuraVent...Tech-Class-A-Chimney-Pipe-Double-Wal/27016678
It looks like it should fit perfectly, but was about a few MM short in diameter to properly slide/screw into the existing chimney. Did Duravent change their specs slightly(this setup is probably 30 years old now) or is this likely some other brand. If another brand, any thoughts on what that might be and where the best place to get a section that will fit?
thanks,
-ed
DuraVent-6DT-36SS
thanks,
-ed
