DVL stove pipe length
You want a telescoping section and then as few joints as possible
Reactions: Highbeam
Looks like a 48" + 12" + the telescoping 40-68" will work.
For aesthetics then I would get a 3’, 2’, and then the slip. The little 12” would look goofy.
There is no 3' DVL in the catalog.
Reactions: Highbeam
If this is connected to a tall chimney, then a 6" damper section could be added on top of a 6" stub to make it look a bit more intentional.
The 9' of chimney pipe and 12' of stove pipe for a total of 21 ft . Should I include the 6" damper on top of my jotul carabassett ?
Buy the dvl adapter for the the stove flue collar tie in, just be advised that its 5 5/8" so not quite 6"
116" is just under 10' of stovepipe. That may work fine without a damper. Your call.
