Need to raise stove up to old brick work level to put the R 1.5 hearth pad under stove.. Looking for easiest way - don't need finishing touches like boarder around new pad.. Stove will sit back 4 or 5 inches from where it is now.. I take it whatever new section will have to be grouted to the current front edge of the brick..
Guess I am saying a temp floating pad of: tin / plywood / hardiboard? / thin tile cemented to hardiboard / then the R 1.5 hearth pad! Then you have to glue that to the front edge of the old brick?? Can I use sand in that gap?? What can I use so I can pull the floating pad out / apart if making a more perm. hearth later..
