When looking at stoves and BTU per hour a piece of wood has a set amount of BTU. The efficiency % between 76% and 80% is not huge and this is running on high heat output. Is the main benifit of a catalytic stove to be able to run lower heat for longer burn times when you are in the off seasons or if your stove is over sized?
![[Hearth.com] Efficiency of secondary, catalytic and hybrids? [Hearth.com] Efficiency of secondary, catalytic and hybrids?](https://www.hearth.com/talk/data/attachments/307/307260-21802e8b29dcfb028a0bf291eba64940.jpg?hash=ZnArlQMxwp)
