We are having major smoke issues with an EKO 60 basement installation at work. The chimney is unobstructed with a good draft. Additionally, I installed a Tjerlund draft inducer fan on the flue pipe which creates quite a suction. However, the boiler still pours smoke out the door whenever it is opened. There must be some kind of thermal loop in the doorway itself. My though is to weld a 3" wide steel plate across the top of the opening at a 45 degree angle. This would slightly reduce the height of the opening, but the advantages seem to outweigh that. Has anyone tried this? Currently the opening is higher than the flue exit which may be part of the problem. Why don't they put the smoke pipe on the top of these things?
Dave
