If your house is plumbed in copper, and has a ground from the panel clamped to one of the cold water pipes , what do you do with that ground if you swap the copper for pex? Asking for a friend...
Traditional ground rod. Actually 2 of them is better. Mine is 2/0 copper cable with a bronze clamp. When the new masonry stairs go in I’m adding #2 where it will see better moisture.If your house is plumbed in copper, and has a ground from the panel clamped to one of the cold water pipes , what do you do with that ground if you swap the copper for pex? Asking for a friend...
The rule isn't that your electric system needs to be bonded to the water pipe, it's that the metallic water pipe needs to be bonded to the electrical grounding system. If the metal pipe disappears, so does the grounding requirement.If your house is plumbed in copper, and has a ground from the panel clamped to one of the cold water pipes , what do you do with that ground if you swap the copper for pex? Asking for a friend...
However, if you have any remaining copper pipes hooked in to the PEX, you need to ground those.
How is changing copper to plastic piping an upgrade? Copper has several advantages, especially if it is already existing. Yes, PEX may be easier to work with, but it's still plastic.When I upgraded to pex from copper I disconnected the plumbing ground. My waste pipes are copper so I kept that ground attached.
Copper corrodes and can burst if it freezes.How is changing copper to plastic piping an upgrade? Copper has several advantages, especially if it is already existing. Yes, PEX may be easier to work with, but it's still plastic.
PEX Plumbing Disadvantages: What You Need to Know
When it comes to thinking about installing or replacing your plumbing, you probably get overwhelmed by the options. Even if you are doing a smaller job, it can quickly spiral out of control as you stand at the hardware store trying to determine the right materials, sizes, and shapes. PEX...smartchoice.plumbing
There are advantages to each. My house had a copper plumbing system with lots of nonfunctional shutoffs and it had been tapped into and modified so many times it wasn't worth trying to work with. So I went with a manifold block and PEX it was much cheaper faster and easier than replacing with copper.How is changing copper to plastic piping an upgrade? Copper has several advantages, especially if it is already existing. Yes, PEX may be easier to work with, but it's still plastic.
Yes, I can see if the house plumbing is a total mess how it could be an upgrade. It's cheaper, faster and easier, but with caveats. Once properly set up, copper is no maintenance. I will stick with all copper supply plumbing in our house. Health and rodent concerns outweigh the advantages for me.
Are they replacing the pipe coming through your foundation? If not, run the ground to that pipe.
I think this is even more important with the flexible SS gas line that is covered in yellow plastic. We have had inspectors here saying the same thing. Do not ground the gas lines. A metal water line coming in from municipal can be the best ground available. Sometimes too good. I had to call a local power company to come out and inspect their ground at the pole because i could see an arc when I pulled the ground off the water line coming into the home.in mass i've had inspectors say to get the ground wire off the gas line. for safety sake because of lighting. it doesn't matter to the code book that you have a ground thru your main water supply or the size of the service i have to run 2 ground rods 8 feet down and they have to be a minimum 6 feet apart for any service change or panel change. bonding is just that. bonding. if a water supply some how gets energized most likely it will be outside of the house and most water not all will keep it to earth ground outside. the only thing that gets a bonding wire inside the house that i'm aware of is copper pipe system or a jacuzzi tub. anything metal within 6 feet has to be bonded to the motor or motors
I'm not an electrician either, but my understanding is conductive water pipes are grounded for 3 reasons:
1. The water line has/is being used as the service ground for the house
2. To avoid a voltage energizing the water piping from a source exterior to the house (lightning)
3. To dissipate the voltage should the piping become energized within the home.
If you are replacing the copper pipe at the entrance to your house items 1 and 2 should no longer apply, the way I see it number 3 may still be an issue if the rest of the copper piping could somehow become energized.
If this were me I'd be giving the city electrical inspector a call, our inspectors are good about answering questions like this, because quite frankly it's up to them to decide how to interpret the code and whether to pass an inspection.
