Just bought a new buck stove 51 insert and having it installed later this week for next year. I cut and stack my own wood and I am thinking about getting a splitter. Previously I have just stacked the wood not split and then tried to avoid using the big pieces unless needed. Since I am planning on burning 24/7 next year as primary heat I need to have all the wood I can ready. Rural king has a electric splitter 4.5 ton yard machines that will spit up to 14 inch diameter and 20 inches long which should cover most my needs. Does anyone have any experiancing with one of these or similar? https://www.ruralking.com/Store/detail.aspx?ID=19680
The price is 200. That I can afford but 1200 for a gas powered I cannot after dropping 3000 for the new insert, liner, and install. Also how small do you usually split pieces down to? Is it better to split now instead of later? Thanks for the help.
