My insert is in the family room, I have a whole other section and upstairs that it will not heat....
The thing is using one third of the juice of the old one and one cubic foot larger capacity. 117 watts running and 700 defrost.Check the box on a killawatt, can't be 500. My HD DVR box draws about 70.
For the other loads, you can rotate. Fridge can be run a couple hours a day only and stay cold. 600 watts of lighting is just insane. Get some CFLs or light a few candles. Coffee pot uses 800 but it only takes 10min to brew, turn the heater off while using it.
Tell the kids its a camping trip. Read books, play board games. They will adapt to less.
Thanks guys, I could have overstated the watts on the lights and the box could be the total maximum, are you seeing that I should be ok with the 3200?
Inefficient? If I have no power, but i do have a proper size generator and 2 portable electric heaters that will heat the area that I want, how is that inefficient? That's the whole purpose of having a generator....I have the heaters, I use them as necessary, ie.basement both units heat my entire basement nicely in 30-50 minutes in the middle of winter, or kids room when I'm not turning on oil till the house really needs it...3200 should be plenty, without the electric heaters. Burning gasoline to make electricity to then convert to heat is EXTREMELY inefficient, a gas motor is (IIRC) only 10% efficient, and that's not counting the losses converting to electricity. You'd be MUCH better off with a couple of kerosene heaters like this:
http://www.northerntool.com/shop/tools/product_200442151_200442151?cm_mmc=Google-pla-_-Heaters, Stoves + Fireplaces-_-Kerosene Heaters-_-173410&ci_src=17588969&ci_sku=173410&gclid=CNDsxrbwkboCFQnhQgodQxsACQx
How much more gas does a 13 Horsepower engine eat over compared to a 6.5 and please don't say 6.5....
I'm just trying to figure out if I should buy the 3200 or the 5500.....
In that case, you will have to buy the big generator and suffer the fuel expense. You're talking 3000 watts of heaters alone.What your saying I'm sure is absolutely true, but that does not pertain to my situation is. Kerosene heaters are banned in my state, I want to use what I have, I just want to purchase the right size unit..... Thanks for answering the question BB.
Great thanks... So now I need to see if I can get away with the 3200 because I want to save on the gas....Fuel use will depend on your loads.
In my case when powering the same loads, my 5500 watt old B&S genny uses 2 galls of gas every 3 hours and my 2000 watt Yamaha uses 0.5 gall every 3 hours.
As the small Honda/Yamahas are very fuel efficient, I agree with BB that a 9 hp genny would use double that of a 6.5. So a 13.5 genny will use at least 3x a 6.5.
Yes you are right, thanks again....If they are oil filled radiator heaters you could run them on low or medium using around six hundred or nine hundreds watts each.
Thank you for taking the time and effort to search about the kerosene, I had a heater in the house when I was young but I would just prefer to stay away from that route.... Those electric heaters wouldn't need to be running full blast all the time simultaneously, so I may be able to get away with the 3200. But they are on the list of something I may want to use if need be...In that case, you will have to buy the big generator and suffer the fuel expense. You're talking 3000 watts of heaters alone.
Unless your particular municipality has banned kerosene heaters, they are not banned for use in single-family dwellings in N.J.
"In New Jersey, kerosene heaters are banned by law from
use in commercial establishments and multiple-family
dwellings. In addition, some municipalities have
ordinances that further restrict your use of kerosene
heaters and some types of electric heaters. You should check
with your local fire inspector to find out if your
municipality has any ordinances about space heaters."
http://www.state.nj.us/oag/ca/brief/heaters.pdf
Can you further explain clean power? So if I go cheap, I could be hurting my tv?with all the electronics you want to invest in something that makes clean power like a honda. I doubt HF has anything that will not be harmful to all the components listed. The Irony of a cable box is that a power outage is most likely caused by a downed line, probably from a tree. most of the time when the power goes out the cable and phone are out also.
My generator load just got a lot lighter. My new refrigerator has now run 48 hours. On just 2 KWH, defrost cycles and all.The thing is using one third of the juice of the old one and one cubic foot larger capacity. 117 watts running and 700 defrost.
I wrote this on another generator thread recently re: clean power...
Electronics like computers and TV's all convert the as power from you wall to DC internally to power the circuit, this conversion filters much of the noise and they are actually a lot less sensitive to the shape of the ac wave then we think. Problem is that cheap contractor generators use an rpm governor to maintain 3600 rpm to make 60 hz and 120v and as the load changes the lag in the governor reaction causes spikes and sags in both voltage and frequency. That does cause electronic damage.
The solution if you are willing to spend is to buy an inverter generator from Honda, Yamaha, Champion, etc. Inverters have other benefits as well - better fuel economy and typically much quieter.
Alternately a cheaper option is to hook up sensitive electronics to your generator via a good quality UPS or line conditioner. This is what I do. The UPS has to be a 'true sine wave' model ( I use APC SmarUPS). You will probably have to turn down the UPS voltage sensitivity or it may just go on battery even connected to the gen.
