We're in a 27 year old house with a handful of copper fittings that have already been replaced. My guess is that we will be looking at a repipe at some point too. Not quite sure how this gets done in a traditional two story colonial with finished basement (no easy access to pipes...)After years of chasing rotten, leaky copper in my place I finally got fed up. Got out of bed one morning and stripped out the copper entirely. 8 hrs in total replaced all my lines. Done. Never had another plumbing issue. Great stuff!
Not sure either! Fortunately in my case the lines were mostly accessable. I only had to get into one wall.We're in a 27 year old house with a handful of copper fittings that have already been replaced. My guess is that we will be looking at a repipe at some point too. Not quite sure how this gets done in a traditional two story colonial with finished basement (no easy access to pipes...)
I did the same when I moved into our new house. It was early 1970s copper that had been cut into many times bad shutoffs etc. Roughly 8 hours as well. With a manifold and run for each fixture.After years of chasing rotten, leaky copper in my place I finally got fed up. Got out of bed one morning and stripped out the copper entirely. 8 hrs in total replaced all my lines. Done. Never had another plumbing issue. Great stuff!
I'm a DIYer, not a plummer. When my two tank system lost a tank last in Q1 of last year, I dropped in a tankless electric but found the gal/min output was terrible and didn't want to up my service panel to handle a larger unit knowing I'll eventually be replacing grid with solar. So, I opted to drop in a propane tankless. I limped along until last month on one tank but then, had enough and started my project after a lot of research. I've done a few sweat joints in houses I've owned in the past. But, this time I opted for Expansion Pex (PEX-A). I got the Dwalt tool in a kit because it was the most available at my local hardware store, a roll of PEX-A, and some fittings. I chose this over push to connect because a youtube video I saw where plumbers did a fitting pressure test of Pex-B, Pex-A (expansion pex, propex), sweat copper, and sharkbite Push-to-Connect. Under pressure, the only fitting that failed was the Push-To-Connect. The rest burst the pipe first. NOTE: Sharbite is a confusing term - in that some people mean "push to connect" when they use the term, but that company makes PEX-A products as well.We have developed a leak at 3/4" copper elbow at a hard to repair location. This is the second failure in this line. It went in new in 2003, but the plumber was sloppy and did not wipe the joints after soldering. I turned the water off on that line and am now contemplating repair options. Getting this elbow replaced will be difficult as it is very close to two other pipe and an abs drain. I'm tempted to do an epoxy bullet around it, but I know that is a bandaid.
The other option I am considering is bypassing this section of pipe with PEX. However, I have never worked with PEX before and have no tools. There would be two joints: one above the elbow and above the built-in cabinet the 3/4" line runs behind, where I can get access. This would be on a straight piece of pipe. The second joint would be in the crawlspace, on either the straight run of the pipe. For the lower joint, I could solder on a male or female 3/4" threaded fitting if that helps.
What are my options with PEX? I have no PEX tools and it doesn't make sense to do this for two fittings. Do the push fit, slip-on fittings (Sharkbiet or BlueFin) really work and hold dependably forever? Should I look for a compression fittings instead?
Also, the pex line would be run vertically up behind the cabinet and then need to do a 90º turn in the crawlspace to meet the supplying hot water line. Does one put an elbow in the pex or let it make a large sweep 90º turn to eliminate the two extra connections at a pex elbow?
Is you water very acidic?After years of chasing rotten, leaky copper in my place I finally got fed up. Got out of bed one morning and stripped out the copper entirely. 8 hrs in total replaced all my lines. Done. Never had another plumbing issue. Great stuff!
The pex is now in and pressurized. Thanks for all the detailed advice. It's a leap of faith to trust those sharkbite connectors but there are no leaks. One thing I learned is a coil of PEX does not like being made to go straight. Will it relax into shape over time with hot water running in it?LOL, I was referring to moresnow's house. I hope we stay leak free. Normally I prefer soldered copper and have done a lot of it in past years, including full hot water heating systems. But this was much more of a challenge. The lower leaking fitting probably was a bad solder job, though it took 2 decades to start leaking. It was deeply nested in wiring close by coming down from the electrical panel and two other pipes. No room for soldering in place there.Nope, it was a poor installation. With the pipes not lined up straight the fitting must not have seated properly. He just replaced it with a new shark bite fitting. Has been holding for a few hours.
Well also if it was in such a tight spot, maybe plumber only got heat to 1 side. I've soldered joints that have held with just a ring of solder around the edge of fitting and not fully sucked into the joint. This can happen easily for many reasons. They obviously are subject to failure somewhere in the future. I've also seen where the solder flows almost completely in the joint but leaves a sliver of unsoldered pipe that leaks. Usually from not being clean, incomplete flux job or water drop blocking solder from running.So the theory is that the lower joint failure was a bad solder job that eventually started weeping. I haven't cut open the upper 45º elbow that got the pinhole leak, but a contractor I know came up with an interesting suggestion. He used to build houses in LA for the rich and famous. These places were often sprawling mansions with long plumbing runs. In order to have on demand hot water in a far bathroom they often would have hw recirc systems. If the plumber was lazy and didn't debur the interior of the cu pipe after cutting it with a rotary wheel cutter, then the coupled fitting could get turbulence inside that wore out the inner radius. Sounds wild, but that is exactly our setup and exactly the location of the pinhole leak. I may do some surgery and see what the inside of that elbow looks like.
We do have a high mineral content/hardness rating from the Limestone aquifers. Nitrate and bacteria from agriculture runoff is our real issue. I really should be filtering. Enjoy your steak, porkchop and chickenIs you water very acidic?
![[Hearth.com] Emergency water repair, PEX option? [Hearth.com] Emergency water repair, PEX option?](https://www.hearth.com/talk/data/attachments/290/290045-3cd6433c7f4bbee015358d001872b9c0.jpg?hash=kcREgNEAjO)
