England PVD 25
Charger66
16
Amsterdam, NY
Hello everyone, I have one question for you all, what RPM does the combustion fan motor run at on the England pvd 25 pellet stove right from the factory in 2009? Thanks in advance.
3000rpm .97amp. should have all the specs on the old motor housing. they are very sensitive to the amp draw. the board circuits are designed to handle 1.0amp
Thanks for the reply. I was having Lava forming in the burn area and was wondering if the blower was at fault. I since have found the problem. It ended up being the exhaust ports behind the large plate in the burn area were 95% blocked with ash. I vacuumed them out then blew them out with the blower going and a leaf blower. I also plugged the bottom holes under the burn plate and the top hole over the burn plate. Now it really burns nice. Strong flame and more heat output than it ever had. I want to thank everyone in this forum for their insights and tips it really helped me out a lot. Thank you.
99 times out of 100 its a dirty stove. Now you know and troubleshooting problems will be even easier. ;)
