I still have not pulled the trigger yet on this stove, although I am 95% sure its the stove I want. Anyways I need a few measurements of the stove to verify it will fit in the location I want. If someone could measure the overall length and width that would be cool. Also I need the distance from the back of the stove to the flue connection. I am assuming its in the center of the stove left to right, but I cannot remember if its all the way flush at the back of the stove.
The problem I have is I am trying to place it as close as possible (left to right) to my existing chimney, but I also need to work around the ceiling joists and the roof peak. Of Course where I want the stove would put the pipe right through the peak, so i might need to use two 30degrees sections to allow some flexibility between the stove and chimney locations. Also how close can I put the stove to an Existing Brick chimney?
