For the past week. I have had a couple of situations where I have woke to the stove off. Seems the top Auger just stops. I Empty the hopper clean any fines, vacuum and clean everything. I haven't removed the Auger Motor or Auger, however both times It seemed like the Auger was Jammed. I gave the motor a twist and it seemed to clear any jam and works great.
Last night I woke to smoke in the house the stove was off and I had a small fire (Smoldering) pellets in the feed chamber.
I am going to take everything apart this morning however just want to get an idea of what might be causing this other then the obvious.
1. Bad Auger Motor? (How can one check this issue)
2. Pellets jammed causing the auger to bind up?
3. Clogged door vacuum port?
Thanks.
Frank
Thanks.
Frank
