230 volt Enviro Windsor Auger Problem
Thanks for this. Until yesterday the problem was that the auger was turning and there was a good flame for a while and then it stopped delivering enough pellets to keep it going. Last night the auger simply decided to stop turning after about 40 minutes of running well. However, when I plugged it in to my test cable, the auger motor worked fine. I might try looking at putting a jumper lead across the vacuum switch to see if this has any effect.
Can you get a new control card? It is sounding like either a bad connection or board issue. The vacuum switches themselves usually don't go bad, but if the combustion blower wheel is dirty ect the vacuum could be too low. Usually once the vacuum switch closes, it would stay closed until the stove shuts down normally. If the flame appears good, that is another indication of a good vacuum and air flow. Try the jumper, as it's free, first.
Just wondering, is your stove connected to a thermostat?
Reactions: Washed-Up
Thanks for sticking with me on this. No, the stove isn't connected to a thermostat. I tried again today, bypassing the vacuum switch with a jumper lead. This made no difference. The rate of pellet feed was fine until about 40 minutes in when it slowed down and the stove went out. I had left the back off the stove to see what was happening. It is possible to see the motor shaft going into the gearbox. What seemed to be happening was that the shaft was sticking at certain times slowing the rate at which the auger turned. I'm wondering if the motor which is now 20 years old is simply getting tired. I can get a 220volt one with a similar spec from Italy for around 185USD and I'm trying to decide if it's worth a go.
You could do another bench test with the motor/gearbox. This time run it for an hour. The gear box would be the load. If you suspect any issues, unbolt the bearings, and then put it all back together. If the bearing brackets are not perfect, it will stall.
Have you taken the cover off the gearbox on the auger motor, cleaned out the old grease, and put some new in?
You have an unusual problem!! Other possibilities: the control panel. The proof-of-fire sensor. Also check all wire connections for tightness and corrosion.
Thanks again. I have cleaned out the old grease and put new in although it looked not bad when i opened it up. The house is very dry so no evidence of corrosion and there are no lose wires. Will look into your other suggestions if I can figure out how to test.
Tried again yesterday. Once again started up and ran fine and then the motor seemed to stick. Disconnected the motor and connected it directly with a test wire and it went fine again, so it isn't the auger motor.
Does the combustion fan run until or before the auger has stopped? Does the auger just slow, then stop, or just stops?
Can you restart immediately after it stops, or does it have to cool down first? Is your stove clean ? Video of internal cleaning
The stove has a high temperature safety switch. If the temperature on the hopper reaches 200°F (93°C), the auger will automatically stop and the stove will shut down when the exhaust temperature cools. If this happens, call your local dealer to reset the 200°F (93°C) high limit switch. (from the manual) Is it possible the HTS is bad? You could jumper it and try. I don't think you did that yet?
I'd also wire up a thermostat and try the other modes to see what it does.
Manual:AUGER PULSE LIGHT: This light will flash in conjunction with the auger.4. MANUAL AUGER FEED: If the unit runs out of fuel, this button can be used to “prime the auger system”. This button will turn off after 60 seconds and then must be released and pressed again.
Does the auger lisht flash when the auger stops? Did you try to puch the auger manual feed during this failure?
HI / LOW: when the jumper is placed on only one of the J9 pins, then the control board is in a HI / LOW mode of thermostat operation (factory setting). Page 5 You can try this mode (check the board to see what position it is in and that the jumper is on) right away. With just the jumper it should keep running.
Thanks again for the suggestions which I will try if I can. I have been away for a couple of days. I undid the bolts at the back of the stove and did a major clean when the problem first arose. The motor appears to be humming and trying to turn but sticking. It works fine when plugged in directly to a power source immediately after sticking. Sometimes it doesn't stop completely but sticks and starts but doesn't move fast enough to keep the fire going. I haven't tried an immediate restart. Combustion fan was still working when auger stopped turning.
It's sounding like it's jamming up. Maybe you can get you jumper hooked up and run the auger with the stove power off. You should be able to feed pellets unless it's jamming. That could be bearings or built up dust. Also, look at the auger carefully to make sure all the welds are good.
The truth is, in my 20 years as a tech, I never ran into an auger motor that ran and then stopped as if stuck. My suspicion is that when that motor gets hot, it is worn out . A motor that hums is being fed power but does not have the Power any longer to turn when asked to do so.
I could be wrong. After the tests you have done, it leads to one thing: the auger motor is weak. The overheat sensor was suggested, but it is manually reset, not automatically reset. Your vac switch seems ok. It either works or not, as long as vac is present. The only other thing is the control board, but the auger motor hums, which indicates the board is good. I have run out of possibilities. I know the auger motor is not cheap. It would be my next step
Many thanks for this Johneh. I took a few days away from the problem as it was really annoying me. I'm writing from a position of ignorance so this may be a stupid question - when the motor started sticking I used a test lead to connect it directly to a plug beside the stove and it turned at just over 1 rpm which I understand is correct for this motor. My thinking was that this indicated the auger motor was OK and the problem was elsewhere but I'm really happy to be corrected on that.
Well, you just disproved my theory. Ok lets go at this differently. When the auger starts to slow down and stop or stick, can you use a voltmeter and test the Yellow wire? It should read full voltage. If it does not, then the board is at fault. The reason the board supplies full voltage when the pellet timer is on. The voltage is basically on and off and should always be full voltage. Remove the board and look at the circuit board for discolouration. Dark brown or black, even just a pinpoint. Looking for a high-resistance point
As Johneh said, this switch if activated would normally latch out, but in case it's defective, you could try to jumper it. It seems it stops feeding when the stove is getting hot..I think you already jumpered the pressure switch. If you are able to get a voltmeter connected to the auger motor that would show what's going on with the voltage.
  • [Hearth.com] 230 volt Enviro Windsor Auger Problem
Thanks for the suggestions. The stove has done very well lasting for 20 years with little maintenance except cleaning and changing the ignitor a few times. I may have to admit defeat and get a new one but would be keen to fix it as I prefer how it looks compared to what is available here now and obviously it would save a lot of money if it could be fixed. There are so few sellers around I haven't been able to find a professional to look at it.
So I finally got to doing some voltage measuring. When the auger motor pulsed the voltage went up to 230 even when the motor appeared to be sticking. This is particularly weird in that when I connected the motor directly to 230 volts it turned at a rate of just over 1rpm without sticking which is correct for this auger motor.
Those little motors can stall, and not blow the main fuse. They would probably heat up if left like that too long. If it was getting 230V, and working fine, then getting 230V and not turning, it is most likely stalling. I'm not sure about the next step. It appears the control card ect are OK. Is it possible to turn the auger by hand with the gear disconnected? Or feed pellets with the motor jumpered on 230?
Thanks for replying. I did try turning the auger by hand when I had the motor out to change the grease and it was a struggle to get it to move but that didn't surprise me. I did also clear the hopper out completely and of course there was no trouble turning the auger when I did that. The motor turns at just over 1rpm and feeds pellets when directly connected to 230 volts.
It's looking like you need to try another auger motor/gearbox. Make sure to try some different pellets first. The ones I use are 100% softwood. Maybe the pellets you use a binding the auger. They all should be within a minimum and maximum length.
If you can find the motor itself that would be cheap. Sometimes they might use the same one on a bbq bbq rotisserie. I will look later
It's hard to search here as it's 120V. I'd need a VPN
The Italians seem to have the lead in Europe for pellet stoves and parts. I have got a couple of ignitors there in the past. I have seen a motor that looks like it would do the job on ebay
MELLOR Pellet Stove Feed Motor 1,3 Rpm 9,5 mm Shaft FB1192 FB1392
so trying to decide whether it is worth a go or if I should accept defeat and get a new stove since my one is 20 years old.
Thanks again for all the suggestions
I ordered it and received a note from the seller offering to check that I had ordered the correct one. It was listed as suiting an Enviro Windsor but I gave the seller all the details just in case. Will report back on results when it arrives. Thanks again for all suggestions.
