Englander 25PDVC
JW Moto
20
Amanda, Ohio
My pellet stove starts, runs with good fire, then will have no fire, then fire will go again. Almost like it is shutting down. I'm getting no code that there is a problem. All new gaskets, using premium pellets, have cleaned the exhaust pipe.
its cold here, any suggestions?
did you clean the insides? pull the impingement plate, vacuum down in the heat exchanger? clean out the combustion motor fins and chamber?
Reactions: JW Moto
I do clean under the plate where the burn pot is, not sure what or where the other 2 units are. I’ll look in the paperwork.
What heat setting is your stove set to when this occurs? Almost sounds like its on a thermostat.
