englander summer heat /pd55
e2 error on stove chimney clean .not feed pellets
Check the end portion of the vacuum line where it meets the combustion blower. Very common for the rubber hose to become brittle and crack. Cut off the bad piece and reconnect. Hope this helps...
thanks for your help.all fixed now auger jammed real bad clean auger grease and reassembled all well .auger never took en apart before.stove bought in 2006 it a secondary stove breckwell is my main stove also run a breakwell in my pole barn also. thanks for try to help
FYI, annually I switch the auger motors to even the wear and tear on them. One runs continuously and the other intermitently.
