- Jan 21, 2013
- 249
That's why they sound like chitThese stoves are solid state…![]()
!That's why they sound like chitThese stoves are solid state…![]()
!Have you checked your gaskets and how are you with electricity?
Has your stove ever operated on a t-stat? A low fire on higher settings can be caused by a stove thinking it is on a t-stat and there being no t-stat to call for heat thus it sits in maintain fire mode (heat range 1).
thanks!
I agree w/ Smokey. If the stove is not on a stat, there has to be a small jumper wire inserted into the connectors where a stat wire would be. It's on the back of the control board. If the wire isn't there, the stove will always run on lo fire.There should be a jumper on the control board IIRC if there is no stat, hopefully it hasn't fallen off or loosened.
I'd jump the vacuum switch just for giggles.
Look at diagram #4 on P/ 22....bottom right corner of control board...."wall thermostat". That is where the jumper wire needs to be, and check that the screws are tight.
Those are not supposed to be holes. Those are supposed to be two bolts holding the fire pot in place. If these bolts are missing that would explain why you have a bad flame as the fire pot will not be tight to the gasket and the air will not be directed through the pellets. Are you sure those are two holes and not two bolts? It is unlikely the bolts if in place would allow any smoke to escape from there.At least we know the fire alarms work...... 2am this morning the stove started pouring smoke out of the two holes on the bottom front. Not fun to wake up to that!!
there are 2 square holes under there as well as the two bolt holes, im assuming this was where the smoke was escaping.
i see you were able to talk to my tech department this morning sorry i wasnt able to take youd call myself but i was extremely tied up at the time. if you are still having issues please let me know.
My bad! I was thinking of my PDVC.Those two "sqare holes" are the airwash intake, not bolt holes......
PDVCs have 'em,too. Underneath bottom lip just under left edge of door and under hinges.My bad! I was thinking of my PDVC.
Working on it. If there were a better selection of double wall pipe in my area I would be a lot better off. That pad was there for my wood stove and I was unable to get the pellet stove to line up with the chimney in the ceiling with out being off center like that. Thanks for the heads up!no prob, BTW your floor protection is not to code, right side is too close to the edge by my eye.![]()
And while we are taking friendly jabs.... Where the hell is my WiFi control board Mike?!no prob, BTW your floor protection is not to code, right side is too close to the edge by my eye.![]()
And while we are taking friendly jabs.... Where the hell is my WiFi control board Mike?!![]()
