Esp or control board
Spaztictyper
65
Nova scotia
My new Harman p61, is changing temp settings all by itself. Or just starts on a higher setting. Some times it will start on 1 where it's set and go up to 2 or higher. Other times it starts on 2 or higher and doesn't change. Sometimes starts on 2 and goes down to 1. ( You get the picture)
The place I bought it from doesn't have the testing equipment so I'm trying to narrow it down to control board or ESP. Other companies won't touch it because they didn't sell it to me. So I'm between a rock and a hard place. I have a correct board from an updated p61, should I try it, with a correct pin configuration? Any help would appreciated. There's a video of what I believe it should be and what it is now based on what my old p61 did. Am I nuts?
  • VID_20261006_120124521.mp4
    19.8 MB
  • [Hearth.com] Esp or control board
Google for an NFI Certified pellet technician. You might come across one with Harman training. If you find one, they may have the diagnostic tools to resolve your issue…
Reactions: Washed-Up
This is what I've read as an answer. Because the distributor fan sucks air in from beside the exhaust it cools down the ESP which as a result turns the heat up in the stove. I've noticed that turning the fan off causes the huge change in flame. Make sense? The 2 pictures show the difference. My old one didn't do that. This is one 1. The exhaust pipe is wrapped in insulation, so I doubt it's the problem at least outside the stove. Can't see and further in with the cover still on
Not taking it apart as it's still under warranty.
