I may be way off base here but I am used to Englander stove modes being a, b, c, d. not 1, 2. Are you confusing heat range with mode?Its set to #2 which he said was correct for my stove.
If the control board is in the wrong mode it will deliver the wrong amount of pellets.
My stove has only one auger that drops pellets down a slide. I can't see the actual auger turn because it is covered with pellets. I timed when I could hear the auger actuate.
ok....now settings the same.....4-4-1.......heat 1.....blower at 5........auger runs for 1 second and off for 6-7........
If I am not mistaken, to compare apples to apples you would have to change your Low Fuel Feed to 1. Or I would have to increase mine to 4.
I removed two more feet of horizontal piping. This should put me at an EVL of around 4-5. I'm gonna bump up my heat setting and see what happens.
My stove came factory 1-4-1....but I need to run mine at 3/4-4/5-1.....depending on the pellet I use.....and yes, we have the same stove just named differently....TimberRidge/Summers Heat......etc........
You definitely seem to have some type of air flow issue...I know it's frustrating but it will get figured out....
Is it possible for you to post a video of the stove burning?
Is there a separate fan for the OAK? Or does the combustion fan create suction?
The wall thimble that I have has the cutout for the OAK in it. It exits on the bottom right corner of the thimble if you are at the outside of the house looking in. I read about the gasket on the hopper lid. My lid bows up on the right side. Could this be a source of the issue?
The model of the wall thimble is 3PVP-WTI.
Probably 1/8th of an inch? It certainly is not sealed against that gasket. That is for sure.
