With this year being poor for opportunity and excess, I ended up buying 2 cords of 'Green'.
I've been researching methods of expediting the drying process and found a few interesting ideas/ processes.
I also see it's bee talked about before here, but I don't see any listed results.
So, if you have done something on these lines, I'd love to hear what you've done and how well (or not) it worked.
I have 3 experiments running in the yard (ya, I'm serious about expediting drying) right now to see what works or doesn't.
The readings I will state are at full sun and ambient temp in the mid 60'sF
First is the 'Big Black Box'.
I took an old set of pipe staging and an old ladder (for shelves) and created a black plastic box.
The wood is stacked front and rear full, with the middle being open for air movement.
The ends of the middle was also stacked to create what I hoped to be a chimney.
Using 2 of my little solar panels and a computer fan, I set that up in the center to move air.
Since there is no vent at the top, I felt the fan is a must.
I have since added a second sheet of clear plastic, slopped off the unit to create more heat.
Unit reaches 98F in full sun inside.
![[Hearth.com] Expeditided Wood drying / Solar Kiln [Hearth.com] Expeditided Wood drying / Solar Kiln](https://www.hearth.com/talk/data/attachments/176/176533-5333ff4967aec1ff2ba64a8339423dde.jpg?hash=p9r8-FcadA)
(broken link removed to http://i988.photobucket.com/albums/af10/olddawgsrule/IMG_0986_zpsface77ab.jpg[/IMG)
