Took my FLIR outside this morning to check for outside leaks as it was 3 degrees this morning and knew any heat loss on the exterior would show up well. The heat loss on my exterior chimney is quite evident in the picture. One good thing about my chimney setup is the other side is completely exposed in my house as the ceiling goes to the roof line. I shot the interior as well and its radiating the same heat back inside.
I also discovered that I need to insulate my basement foundation. It was glowing red. I was actually picking up heat on the snow a foot away from it.
Also, the temperature sensor does not seem to be accurate outside when it's 3 degrees.
![[Hearth.com] Exterior chimney heat loss with FLIR thermal imager. [Hearth.com] Exterior chimney heat loss with FLIR thermal imager.](https://www.hearth.com/talk/data/attachments/219/219930-264d65040be59397d35b7779ff0fe2d2.jpg?hash=YeTZyGRjEc)
![[Hearth.com] Exterior chimney heat loss with FLIR thermal imager. [Hearth.com] Exterior chimney heat loss with FLIR thermal imager.](https://www.hearth.com/talk/data/attachments/220/220827-c67863c71b4f71230c4dd103b532af10.jpg?hash=WH-2_qPRfg)
