I have been noticing my burn times are a bit longer and my stove is about 50-100 degrees hotter with my insert fan off or on very low. Seems to be producing more heat. What's the sense of the fan?
I would not doubt that, but that's why you get 3+ years ahead and you don't have to worry about things like that.....Is there any truth about shorter burn times while running the fan?
I think you need more wood in your stove.1 Yr. Ash Trying to keep it 1" from baffles. Sometimes it's about 1/2" form baffles. Pieces are 18" long. 5-6" Girth I can get 3 or 4 in there. Started stuffing it with smaller splits to fill in.
I cut all my wood 13-15" and stuff my stove full straight in north to south.My box is 13" Deep and 22" wide. I have done some n/s. Maybe revisit it just have to cut down my splits. I thought e/w give the longer burn times?
Edit: Cannot really get that much more in unless they are cut flat. Think I am going to stuff it to the gills tonight n/s and see what happens.
Something like 16x24.IW,
What are your firebox dims? I need to cut them down to 12" to load n/s 13" if I keep them tight to the back.
Try this. Put a thermometer in your stove room but not too close to the stove. Run the stove for an hour once you have a steady burn going without the fan. Then turn the fan on and run it for another hour. See what the difference is in the temperature of your room.
Its not about heating your stove up. Its about transferring that heat to your living space. It's about heating your house, not getting another 100* higher on your stove.
I suspect that's the case with mine. My totally unsubstantiated theory is that the hotter firebox allows me to run with less air, resulting in longer burns. At the moment most of my loads are running with the air fully closed. That's only possible with well seasoned wood.Is there any truth about shorter burn times while running the fan?
