Jethro Wood
- Dec 2, 2012
- 23
I purchased the
110556 EF Fan Motor 12VDC, All units, Exmek at a cost of $133 plus $22 in shipping from:
http://sierraproductsinc.net/parts-pellet-stoves.php
The motor arrived well packaged in a few days via FedEx despite the storms in play.
It appears correct replacement for the Thelin fan motor and I was told by Sierra products that it is a replacement. It appears heavier and larger in body diameter than the Pittman motor and the overall external construction appears better than the Pittman. The bearing shields on both ends are visible enough to see the bearings are: Singapore NMB 608Z.
Sierra Products sells brushes for the Exmek motor for $18 a pair on the same link above. Brushes seem to be replaced the same/similar as the Pittman and the bearings and access to the motor for the repairs performed on the Pittman I documented in a prior post linked above appear possible. I don't plan to rebuild this motor until it wears out and then will document here at hearth.com.
Best,
Jethro
Best,
Jethro
