zapny said:Missed on the back cut and think the face cut could have been deeper what are your thoughts?
zap
smokinjay said:zapny said:Missed on the back cut and think the face cut could have been deeper what are your thoughts?
zap
should be two tears "if you will" the back cut 1 or two inchers higher than the face cut and both levels level.
back cut very crocked the hinge looks pretty good and face cut pretty good just work on the back cut even if you have to use a can of spray paint to make it more level.. The way I judge the face cut it should be 25-33 percent of the total tree width
zapny said:smokinjay said:zapny said:Missed on the back cut and think the face cut could have been deeper what are your thoughts?
zap
Smokin and Chad thanks for the info, also should I have cut a little higher on the stump.
zap
chad3 said:Smokinjay,
What I was saying was leave the last cut on the stump and cut it after the tree is cleared. If you are going for firewood, who cares where you cut it, it is going to be cut to small lengths at some point. Leave one cut on the stump and cut it last. I also tend to leave those as markers if I need to drive around the site and cut them as I am leaving (don't want to get hung up or cut a tire on a stump).
Hope this helps my explaination.
Chad
I do the same, well almost. I cut about 3' up. that gives me a couple stove lengths. beats bending over and lets me leave a very low and very flat stump.chad3 said:Smokinjay,
Chad
Wood Duck said:I don't have too much new to add, since I agree with a lot of the previous posts. I aim the back cut for about 2 or 3 inches above the notch to leave a hinge, and this seems to control the fall bretty well. I don't really have any experience doing it any other way, but this way works. Like several others have written I make the felling cuts up at thigh level where it is easy to work. After the tree is down I take the last round or two from the stump. Then I scrape the dirt away from the base and use a plunge cut to cut the roots away from the stump below ground level. After you get all the roots cut, you can rock the stump back and forth to break off the small roots you missed with the saw and the stump will break loose.
Chad
zap
savageactor7 said:zap from here it looks like a 'dutchman'...you're lucky things didn't get ugly on you.
zapny said:savageactor7 said:zap from here it looks like a 'dutchman'...you're lucky things didn't get ugly on you.
It's a ugly cut but I had the rhino hooked up to it with the winch, it needed some help so instead of cutting more the rhino did the rest.
zap
smokinjay said:zapny said:savageactor7 said:zap from here it looks like a 'dutchman'...you're lucky things didn't get ugly on you.
zap
with the winch and wedges just straighten the back cut and a little bigger wedge and your in the big legue just get a few more smaller ones under your belt ,and post pic's should be very interesting.. This is the same way I do it in close around houses but I just use a bull rope no winch but you should be able to drive a tack.....
zapny said:smokinjay said:zapny said:savageactor7 said:zap from here it looks like a 'dutchman'...you're lucky things didn't get ugly on you.
zap
With the looks my cut I guess I'm in the same league has the BAD NEWS BEARS!
Like coach Buttermaker Said to his team, come on fellas Rome wasn't built in a day.
Zap
CaddyUser said:Zap,
Here's a link to Jonsered videos.... It is a good watch, both for the experienced, and well, others like us!
http://www.jonsered.ca/node246.aspx
