A railing guy drilled a wrong hole in a two-inch thick granite step leading to my front door. The hole is about 1" wide. What's the best way to fill that hole? A concrete mix? Some sort of caulking? A specialty product? It'll be under a railing in an unobtrusive spot so the look is not as important as making sure it's filled so it doesn't fill with water/ice and crack, etc. Any help will be appreciated. (And, no, I don't trust the knucklehead railing guy to fix it correctly.)
Thanks!
Thanks!
