Hey everyone. I have a small shop vac all around, and I would like to know if they make some type of filter for ashes. I used it once to vacuum out the stove but had to set the vacuum outside the window. I made a pretty good mess. Thanks everyone!
Thanks RobbieB I am going to try to find the bags for my small shop vac online.
How often would I need to vacuum the stove out? I was thinking once a season.
Truthfully, you never need a vacuum to maintain a woodstove. I've never used one in all my years burning wood.
I think that depends on the woodstove. I have 2 stoves and one of them is a Kent. This one has a damper plate you can pull out partly. On top of the plate is quite some soot after cleaning the chimney. No way you can get that out without a vacuum.
The simple solution is to disconnect the stovepipe before sweeping the chimney. Why make the job harder than it needs to be?
In my set up, a tiny fit in my fireplace, is not as easy. Every set up is different. Not enough wiggle room.
True. And that is one reason I don't like the whole woodstove in a fireplace.
Great tip, Robbie. I didn't even know these were made. I recently cleaned two pleated filters. What a pain in the ass! I'm gettin' me some of those bags.I use the disposable bags in mine. I think they are only made for the larger units though. I can tell you that they make all the difference in the world. My pleated paper filter (the one they all have) would get clogged up minutes after I cleaned them.
After I started using the bags I've never had to clean a pleated filter again. You get full suction all the time and the dust stays in the vac. Yes I have vacuumed ashes from the stove and they stay in the vac too. When full you remove the bag full of filth and toss it inna trash without having to deal with the atomic mushroom cloud of dust either.
Watch the filter when using an air hose.You are welcome. I have a filter cartridge in mine that I tamp clean after most uses and then use I use an air hose to remove what remaining particles are left. This process makes the filter quite serviceable and eco-friendly so I can use it many times over.
