Finding log truck loads
there are a couple of truckers selling loads in the Boston area on Craigslist.
What's the moisuture content?
from AI
The average moisture content of standing trees that have been killed or damaged in a wildfire generally ranges from 27% to 35% (on a dry-weight basis) when measured months after the event, dropping significantly from the 100%+ moisture levels of living green trees. [1, 2]
Key Details on Post-Fire Tree Moisture
    • Time Since Fire: Immediately during a fire, moisture flashes off, and over subsequent months (12 to 52 months post-fire), standing dead trees dry out until their average wood moisture stabilizes roughly between 27.1% and 34.9% depending on environmental exposure. [1]
    • Species Differences: Hardwood species (such as white birch and trembling aspen) tend to retain a higher moisture content (ranging widely from roughly 26% to 53% depending on age and sample height) compared to softwood species (such as black spruce and balsam fir), which dry more rapidly to levels around 17% to 23%. [1]
That’s pricey for MA, I see a lot of truck loads on FB marketplace for 5-800. About $100/cord is the “going rate” in MA for hardwood logs.
Reactions: Smokey Da Bears
from AI
Thanks for posting. I’m getting 15%-38% on 8 year old fire burnt Jack Pine. The 15% stuff is the top 1/2 to 2/3 of the tree with at least 1/2 the bark gone, must be standing. The bottom 1/2 to 1/3 can be as high as 38%. Trees that are sitting on the ground have started to decay and are worthless for firewood. The trees that have fallen but sitting on other trees(not touching the ground) are all over the place on moisture content. Those trees I start cutting in the middle and evaluate from there. The more bark that has fallen off the better the chance of being able to salvage some firewood from the blowdowns.
Welp, the husband of one of my wife's housekeepers came thru, he had about 5 cords of logs felled in 2020 that had been sitting under a tarp in their driveway, that he was just never going to get to at his usage rage. $600 had 5 cords delivered, mostly red oak.
I've already started splitting and stacking it, and will plug away at it the rest of this fall, as time allows. This won't be enough to cover my year, but it's a good start. Still looking for other and better sources, for long-term.
After getting no response from a half dozen land clearing companies, I did call a timber company in Lancaster, but also got not reply there. Local sawmills will be next, I guess.
There are plenty of sources for processed wood, but since I already have equipment for processing and enjoy the exercise, I'd ratehr stick to buying logs.
Yes, this is important. You control split size, length, and get to run fun machinery.
Upper Bucks County near Lehigh County border and I have wood delivered from local tree companies. Normally averages about $80 a cord for logs. Some wood good, some not so much. Last year's load mostly oak and hickory with some walnut so I actually milled the walnut down. This years's load maple, oak, and 4 cherry logs. Will try to mill one of them down. Most of the services and loggers do not want to travel far unless they have to.
Reactions: Ashful
Wish I could find the luck you guys have. Zero companies doing that around here
Have you checked Chip Drop ? after you register, you request a drop and a couple screens in it asks if you want wood chips or logs. Might be worth a shot
The husband of our housekeeper happened to have 6 cords stacked under cover, that he knew he'd never get to use, since he has it coming down quicker than he can burn it. I paid him to deliver it all here in his dump truck, nearly all oak.
That'll keep me occupied probably until the end of this year, and then I'll be out shopping again. One of the posters to this thread PM'd me a good local source, so I'll start there. Thank you!
Here's a picture of the load I had delivered last winter for $450. As others have said, I found these guys on Facebook Marketplace. I've also tried Chip Drop and have received 3 total deliveries, 2 decent (that got split and into the wood stove) and 1 awful (a lot of punky stuff). From my experience, spring to early summer is the best time for Chip Drop at least in my area.
[Hearth.com] Finding log truck loads
