It's definitely coming from under the cast iron on the top of the stove. I did burn some wet wood at the end of the season so maybe that contributed to the staining, I don't know. I just want to make sure it's safe and get it fixed before the winter.
Good morning Dylan,
Thank you for your email.
The staining that you are seeing around the perimeter of your stove is typically caused by moisture/humidity pulling down through your chimney when not in use, and then wicking through the fiberglass gasket which forms a seal to the stone.
One way of mitigating this problem would be through blocking your stove pipe with some insulation in the offseason to prevent the downward flow of air. The key here is to stick a note on the pipe so you don't forget to remove the insulation when you start up your stove at the beginning of the heating season.
To remove the moisture discoloration, I would first start simply by buffing the areas with fine aught steel wool. If that is not effective, and you've stopped the source of the moisture, you can remove the stone from the top casting and use an orbital sander with a very fine grit (220) on the stone.
If you have any other questions or concerns, please let me know.
Sincerely,
Lorin Day
Absolutely great customer service!Thanks for the reply The Bean, and everyone else who replied as well. I got an email fro a Lorin first thing this morning, great customer service from Woodstock for sure...... Here's her reply to my email:
Is one of your AC units blowing towards your Fireview? Wonder if your creating the sweating glass syndrome were the stones are staying warmer then the air your cooling, thus sweating in a sense? Warm air on the chimney side , cold air on the outside of the stone.. Maybe open your draft to allow air to circulate?I think it's more of pulling the humid air down the stack, my house is kept really cool with ACs so that could be the cause in my case.
What's happening is condensation on the cast iron frame. Same thing happens to me in the winter; When I come inside, moisture in the warmer inside air condenses on the cold lenses of my glasses, fogging them up.Is one of your AC units blowing towards your Fireview? Wonder if your creating the sweating glass syndrome were the stones are staying warmer then the air your cooling, thus sweating in a sense?
