Hi everyone,
Im in the process of building a new home. 1000sq ft 1 story ranch mostly open concept. Im considering putting a pellet stove in the living room to heat the entire home.
The floor plan is here:
http://www.thehousedesigners.com/plan/the-chesterfield-5860/?1=0&reverse=False#top
My plan was to put electric baseboard in each of the two bedrooms as backup just in case. My real concern is if the pellet stove can project the heat to the rest of th house ok with just ceiling fans.
I see stove manufacturers say this stove an that stove can heat up to 2000sq ft etc, but im assuming those are a bit biased and would be based upon a single room.
Appreciate any thoughts you may have before I take the plunge to rid myself of #2 in this new home.
) you know what the winter will be like in your area. Where it is a new home, and 1000 sq ft. that should be so easy to heat. Just make sure you follow the smart home building guidelines for sealing and insulation. Whatever stove you get, try to get the one you feel comfortable with. You said you were looking at a Harman. I don't think you would regret that purchase. My raised ranch is about 2200 sq ft. I heat with the one pellets stove until it gets down to the mid teens or less, then my furnace kicks in off and on. My home was built in 1975 with 4 in. walls, thermopane window. Added additional insulation to the attic, had the house sealed when I put on new siding and another layer of insulation. We use a double entry to prevent heat loss. You can make your home so well insulated that you need some way to get fresh air in. I.E an air exchanger. I have a cousin who has a new home. He heat with a heat pump and one small stove.
