Let me start with the background information. Moved into a new house in July and the previous owner had a Dutchwest Extra Large 2462 that he used for heating. The stove was vented into a 12x12 masonry chimney lined with clay. He also left behind ~3 cords of stacked and covered mixed hardwoods. I had the chimney inspected early in the fall just to be safe, and the sweep found numerous cracked tiles and suggested lining the chimney.
So I had a 30' 8" stainless liner installed (stove manual reccomends an 8" flue) and began burning wood regularly. The Dutchwest proved to be a very finicky stove, and I quickly learned that if I had the catalyst bypass open for too long while getting the fire going, flames would roar up the flue and get the liner glowing red quickly. Engaging the catalyst would be enough to get things under control. By early December I had the hang of operating the stove and was burning round the clock. On weekdays I would fully load the stove once in the morning and once at night. On weekends, I might load the stove twice during the day and once at night. Most times I was reviving a meager coal bed.
Then I had my first chimney fire. It burned for about 15 minutes with all air controls fully closed. I figure it was relatively small as there were no flames or debris coming out of the chimney top. To be safe, I had a sweep come out (different from who installed the liner, I wanted a second opinion). He verified there was a fire, swept the chimney and deemed it still safe to use. However this is were things get murky, as he gave me some "interesting" advice.
He said the excessive creosote build up was due to me fully loading the stove. He said never load more than 1 piece of wood at a time, even if it means loading all night long. He also said never engage the catalyst as it will damp the fire, increase the amount of smoke and thus creosote. At this point, I just nodded politely and figured it was time to ask the internet for help.
So what is the likely cause of my excessive creosote build up? Is it bad technique? Burning poorly seasoned wood? I did buy a moisture meter and tested ~25 logs and found most to be about ~12-15%. A few pieces from the same tree read 20-21%.
I haven't used the stove since the fire (it was scary as h*ll!) and I am reluctant to do so until I figure out my problems.
One final question: The chimney sweep removed the mesh spark arrestor/animal barrier as it was caked with creosote. Is it safe to burn with out this? My fear is large chunks of burning creosote flying out during a chimney fire and lighting my roof on fire.
Sorry for the lengthy first post, I didn't want to leave anything out, but I'll expect a few "tl;dr"s.
Thanks for any help in advance.
Cameron
Cameron
