First time posting and I apologize for the wall of text but I like to be clear. My wife and I have a mobile home that is approximately 1200 sq/ft. It currently is heated by an electric furnace so you can guess why were wanting to install a wood stove. We are in southeast Missouri and normally have fairly mild winters but this last winter was long and bitterly cold and costed us far too much. The insulation is what you get with a mobile home, though I am working on adding insulation, new windows, etc. I can get wood fairly cheap and depending on my willingness to cut and split I could get it free. We do not have any codes to be concerned about. I already checked with the county and verified this first. However, safety followed by stove performance is most important. My wife and I work nights so the electric furnace will only be ran during this time and only to keep the temperature from dropping too low.
We have not began anything on this project. I want to run our plans by you all for opinions or concerns.
The stove will be located in the kitchen on the west wall. The hearth is still being planned but basically I had planned to put down one sheet of Durock on top of the plywood flooring, frame the hearth out of 2x4's, then add two layers of Durock and put tile on top.
The walls around the hearth are 2x4 thick and have rock wool insulation with 1/2 thick drywall with metal siding on the exterior. Most of the trailer has fiberglass insulation but due to our plans of having a wood stove in this location we added the rock wool since it is rated for a higher temperature. My plans were simply to add stone tile to the drywall.
The ceilings are vaulted but the lowest point around the stove is still over 7 feet so I don't expect to have any clearance issues.
We would like to avoid going through the ceiling with the chimney and instead planning to remove an old window that has not yet been replaced with double pane like some others. I am going to frame the old window and cap it off on both sides with sheet metal. I was planning to take double wall pipe up 12-24 inches from the stove, turn 90 degrees for about 12 inches (depends on stove recommendations) and switch to triple wall pipe at the thimble which will be mounted to the sheet metal. Outside I was going to use a triple wall tee followed by 6-8 feet of vertical chimney until it clears the peak of the roof by a couple feet.
As for the stove itself we are still undecided. I know it needs to be mobile home approved and use a make-up air kit to pull air in from outside. No matter what stove we use the rest will be the same. Space is an issue. We need a stove with MINIMAL clearance on the back. The stove needs to be wider than it is deep which is not as convenient for loading wood. I wanted a stove we could simply load the wood by sliding it straight in but most I've seen are far too deep for our location. The maximum depth we have is about 3 feet so that must include the depth of the stove and the clearance requirements.
If anyone can recommend a stove with a larger firebox that can still fit in a depth of 3 feet counting the required clearances I would appreciate it. It simply can't be more than 3 feet from the front of the stove to the rear wall. A stove that isn't outrageously priced would be preferable.
Again I apologize for the long post. If you came this far then perhaps you can make recommendations and/or bring some concerns to light that we might have missed. Thank you for your time.
