Flame size on 1
Spaztictyper
58
Nova scotia
Can some one post a picture of there Harman p61 running on 1. This is my second one ( brand new) and it's way higher then my old old one. It usually a little pile of ash, now it's like it's on 3 setting.
1 and what feed rate? Or feed rate and what temp?
Reactions: johneh
Rarely do people run it that low, so you may have a hard time finding someone to respond.
A 1 setting tells it whether it will vent the heat outside, or put some into the room. The feed rate can affect the height of the flame (depending on mode - I assume you are using Stove temp mode as you did last year).
Reactions: Washed-Up
Try in on feed rate 4 and then temp 1 or whatever…I leave mine on feed rate 4 then adjust the temperature pot and it works well
Reactions: NS P-68
[Hearth.com] Flame size on 1
Running it today full time, have to turn the stove fan off, ceiling fan off just to keep it at 74 20 feet away around a corner. It's 44 outside. I can't take a picture of the flame because of the reflective coating on the glass.
Just as I posted, it dropped to 73. Looks like I have to give it a chance. More goofing around to do.
You don’t need a tech…that looks TOTALLY NORMAL! Happy burning ;)
Reactions: ARC and bogieb
Looks just like my PC45 on a maintenance burn after room temp has been met. Which I'm guessing it would be a "1" setting or just a little less.
