Is there any type of connector that connects one flex liner to another flex liner? Bother liners are the same diameter.
if the liners are the same brand yes if not then none that will allow you to do it and meet code no. All of your liner and components need to be tested to work together to meet code. But if they are the same types of liner and the connector fits correctly I don't see any safety issue. but technically it doesn't workIs there any type of connector that connects one flex liner to another flex liner? Bother liners are the same diameter.
Furnace cement will crack and fall out within the first year so I would not bother.at the connection would you seal it with furnace cement or leave it connected with no cement in case you have to clean it?
I would cut that section off personally. But Iwould not put the splice at the bottom.
At the top where it will see less heat.where would you put the splice?
when you say splice it, you mean cut the liner and attach a new peice of liner right? I guess I'm confused on what you mean. If I cut and connect a new piece like 1.5ft above the stove connection, that would be too much heat for it?At the top where it will see less heat.
Yes cut it and attach a new piece using an appropriate connector. And I would not put the splice that close to the stove no. It would probably be ine but I would be more comfortable with it further up the liner.when you say splice it, you mean cut the liner and attach a new peice of liner right? I guess I'm confused on what you mean. If I cut and connect a new piece like 1.5ft above the stove connection, that would be too much heat for it?
You should have cleared the obstruction so you didn't dent the liner in the first place. At this point if it is stuck your choices are leave it the way it is and hope things are ok or yank it out clear the obstruction and reinstall.hmm ok, so I mean in this situation where I can't put it up higher due to it being in a tight spot, what should I do?
it will weaken it some yes. Will it be enough to hurt anything? I don't know probably not but I would not chance it on a customer's housecan I try to work out the dents or will it weaken the steel?
also, just out of curiosity, why is having the splice close to the stove bad? How is it any different than having an angled adapter or something connected?Yes cut it and attach a new piece using an appropriate connector. And I would not put the splice that close to the stove no. It would probably be ine but I would be more comfortable with it further up the liner.
A connection is a spot for a potential failure the appliance adapter is a necessary connection a splice is not and when it is near the bottom where it gets exposed to more heat there is more potential for failure. Like I said it would probably be fine there but I would not do it myself.also, just out of curiosity, why is having the splice close to the stove bad? How is it any different than having an angled adapter or something connected?
