- Apr 21, 2013
- 687
I was reading that Vermont Castings has a flexburn stove with 3 burn stages. What exactly is that? I can't find info.
That's not how the flex burn works. To run in non-cat mode, the cat must be removed. Running with the bypass open is simply that, bypassing all secondary combustion in order to heat the stove up.I have the VC Encore flexburn, a brand new 2014 model. It is not required to remove the cat or anything else to burn in catalytic or direct mode. The cat only needs to be removed for periodic cleaning.
To change burn mode all you do is move a single lever one way or the other. It's that easy. The stove will run w/o the cat in place but there's no point in doing that.
The refractory material has been completely re-engineered. I wouldn't say its fragile. It's much like ceramic. VC has done much to improve the newer models.
(I posted pics in the 2014-15 VC owners thread)You dont want to burn this stove with the damper open unless you are reloading wood or running it with the doors open in fireplace mode with the spark screen.
I can't leave the damper open > 30 minutes without temperatures reaching >800 griddle top and the refractory starting to glow.
its not an operational error to run the stove in direct mode as long as temps and wood load sizes are monitored closely. There's apparently more opportunity for the stove to over-fire if run this way.
The primary air shut limits draft some but not very much with the damper open.
The damper closed the stove runs great...and opening the damper for reloads is great because generally 15 minutes and the new wood is well caught, the griddle temp is 400-500 and the damper ready to be shut (I just always figured this was how the stove was supposed to operate). burn down to hot coals, open damper, add wood,wait for it to catch, close damper, shut down air slowly.
My system may just have excessive draft with the damper open but seems to be just perfect closed.
And damper = bypass plate in the VC world.
It is an intriguing combustion system. I've had fun tinkering with my encore. But mine was free! I built both a cat and a non cat combustion box for it out of skamol, the same material Jotul uses for their baffles. It might seem fun for you now and I hope it serves you well. Most people don't find it funny when I tell them it's going to be $800+ to fix a stove that's still new to them. We quit selling VC because of their "everburn" system, the numerous free service calls associated with it and the lack of support from VC. We only have a few 2in1s out there, they haven't had many problems so far.LOL
We should be neighbors...
I'm having a bit of fun with it.
