Hi Hearthies,
This is my first woodstove and installation of chimney and i'm doing it all by myself so the learning curve here is steeper than the offset I'm planning for the flue. I would so so much appreciate some experienced persons input here.
I'm looking for a wood stove that (by instruction in the manual as per my insurance company) has to allow for a floor to ceiling height of less then 6' feet. My basement is 70" from subfloor to ceiling. Or my other question is can I remove the subfloor and place the stove directly on concrete slab?
The other question I have is regarding going around the roof overhang when installing the chimney. Please let me know if I should ask that in a seperate post and i'll edit if needed.
I'm installing a through the basement wall chimney.
I have a 16" overhang I would like to clear without notching out my suffits. I have read several posts here of people both asking if they can do this, people doing it, and people putting in offsets. I get that the basic idea here is that we don't want a big horizontal run. From stove to vertical would be min 29" and max 36" The chimney system I'm looking at clearly says never put an offset on the external chimney. (I can only assume this has to do with torque force pulling down on it.) In any case I will, but REALLY don't want to cut into my overhang. I'm looking for a chimney system with instructions that allow an offset as part of the through the wall part like this
![[Hearth.com] Floor to ceiling height must be at least 7' (84") in all cases. [Hearth.com] Floor to ceiling height must be at least 7' (84") in all cases.](https://www.hearth.com/talk/data/attachments/247/247797-379604cc4ca5b25a0cad8bdd0aff9285.jpg?hash=8vjrUgbzNv)
Also, comments on this. Is it better to go with a 36" horizontal (inclined i know) or a much longer but much steeper incline. I know from working with water and air pressure that this longer steeper incline is likely to create a much better draft but it's honestly more a gut feeling.
Irregardless of what will work, I need to buy one with instructions that allows a horizontal of 36" or an offset of 36" to clear my overhang. Has anyone seen one or even remember seeing one or is it just never going to happen and I should stop looking and start cutting my overhang? lol
(Yes, I know offsets are harder to clean. and yes, i know most people suggest going straight though the house. )
