I have a half finished basement where my P68 is. The P68 is used to heat the house, so the basement does get overheated.
Currently, there is laminated wood flooring, which is separating where it snaps together. While in the summer it may be damp (I do run a dehumidifier) , I don't have any major moisture issues.
I want to replace the flooring, but not sure if the separating was caused by the excessive heat, moisture or just the fact whoever laid it, laid it incorrectly.
I was thinking of using a vinyl flooring, which is less picky about moisture, but not sure how that will withstand high temperatures.
Any recommendations? I can post some pictures if necessary.
