I'm playing around with a shop-made outdoor wood boiler. Obviously this is a fool's errand but so far it has been great fun.
So far I have a relatively successful stove welded up that has preheated primary and secondary combustion air, lined with firebrick, and has forced air combustion (which can thus be controlled by varying fan speed). Burns quite steadily, accepts a 3' log and will also burn wood chips or wood shreds which I can get free. Depending on the fuel I have been able to adjust it to produce absolutely clear smoke, which I take to be a crude sign of pretty fair combustion efficiency. Such a clean burn should also reduce the potential for flue fires. I plan to burn this thing at full bore, and always when I've operated a wood stove this way I've had no problems with creosote. No pesky regulations around here say I can't use something like this. Gotta go outside in a little insulated hut for safety as well as the fact it smokes until you get the draw right. It will heat a tank of water which then heats the house hydronically.
I plan on insulating the firebox with high temperature insulation (another thread) and then adding a heat exchanger, also homemade, to the top of the whole caboodle. I have no illusions that this will be a long-lasting stove, or high efficiency, however it is certainly fun to build and so far cheap. In a couple of years it will be fun to build again and improve. Usually about the third time I build something it gets really good.
Safety devices for such a heat exchanger are a whole NUTHER important discussion, but the short answer on safety devices is, I will plan to use an open, atmospheric system, which makes it much harder but not impossible to have a steam explosion, and a 500 gallon insulated tank to store the heat in, a pump to run the water around, an aquastat to turn the pump on and off, and temp/pressure relief valves at important points in the system.
All flue heat exchangers in a wood stove will foul, and thus a plan to be able to clean them frequently and eventually replace them is in order. Wood stoves that burn hot and fast and complete will have less but not zero fouling problems in the flue.
Shop-made flue heat exchangers seem to come in about three classes: copper watertubes wrapped around things (such as flue pipe), homemade water tube systems, and home made fire tube systems.
Watertube systems of any kind, whether copper pipes wrapped around flues, or pipes running through flue gas, etc, seem like they would foul quickly and be really hard to clean. Copper won't take the heat, steel corrodes fast. Hilcoil sells stainless steel coils, not cheap however they might be a good idea if one was going to do a watertube heat exchanger that would last. Perhaps any steel box (even an empty "barrel stove") could house a few of these coils, and have an access door for cleaning. These stainless steel coils are certainly a good option, but I am not sure how many I'd need to transfer a reasonable amount of heat, and that system might get expensive fast.
Now, a fire tube system seems to have some attractive qualities. Designed right, if one can access the ends of the tubes, it should be relatively easy to run a brush up and down inside them. This might be a frequent chore. I also was just reading another thread about using an old chain as a turbulator in a vertical fire tube heat exchanger. Good idea and rattling them around might extend the cleaning cycle. If I built the heat exchanger, it would almost certainly be made of mild steel, a disadvantage in durability but an advantage in constructibility. Not sure if such a system wouldn't tear itself to bits expanding and contracting.
Years ago me and a buddy built a DIY fire tube wood-fired boiler out of a couple of old gas water heaters. The flue ran right through the two 3" pipes in the centers of the water heater tanks, and the coily metal turbulators that came with the water heaters remained in place. You'd fill up the firebox with small wood scraps, and the thing would roar once it began to draw. Made 60 gallons of hot water in 20 minutes, enough for a few guys to take tub baths and do load of dishes with some to spare. I have had little luck finding old gas water heaters that don't leak, but this might still be a simple option.
A homemade fire tube heat exchanger is a possibility. I'm imagining welding several tubes into a small 30 gallon drum, which goes inside an outer 55 gallon drum with a removable lid for cleaning. 16 1-1/2" tubes would be the same area as a 6" flue pipe approximately, that might be a design goal. Flue gases go through the tubes (firetube design) and the 55 gallon barrel has a 6" flue on either end for connection to the stove and chimney. Water is in the inner tank, and the inner tank is at atmospheric pressure. An external pump moves the water through the inner tank. Safety devices and controls and makeup water etc. will be discussed in another thread - I am trying to concentrate on the basic design of the flue heat exchanger here. Obviously this would require watertight welding, a feat I am probably capable of with a few tries.
Is there some thread or project folks can point me to that is similar, and was a successful heat exchanger? Am I on another fools' errand with the firetube idea, and should abandon it and stick with water tubes?
