As a practical thought experiment, what diameter of class A chimney would be advisable based on these variables?
The appliance has a firebox with the dimensions:
32in Long
19in Wide
20in High
The appliance can burn wood, coal and oil. The rated BTU outputs for the fuel types are:
Wood: 135,000 BTUs
Coal: 155,000 BTUs
Oil - Max Setpoint: 175,000 BTUs
Oil - Min Setpoint: 120,000 BTUs (this is the setpoint it will be exclusively fired at when buring oil)
The appliance will primarily be fired with oil at the 120K BTU setpoint and the wood/coal as an alternative and backup heat source.
The appliance has an 8in diameter collar.
The Chimney will be plumb dead straight.
26.5ft from the appliance to the top of the stack and located on the interior of the structure except for the 4 ft of stack above the roofline.
The class A chimney will have an exceptional R-value for its type class.
The building has a positive air system (which I cannot confirm is relevant to the question at hand, but I thought it worth including).
Also the building is at 1000ft above sea level.
The chimney installer/inspector is very concerned the appliance will be over drawing, but is adamantly opposed to placing a barometric damper in the flue.
Given all of the above, what diameter of chimney would be best suited to these conditions?
See attached for a diagram. Thanks in advance.
![[Hearth.com] Flue Sizing - Based on the Unique Variables [Hearth.com] Flue Sizing - Based on the Unique Variables](https://www.hearth.com/talk/data/attachments/307/307987-ea974dc301cf83bfb8b1dc92cc0eef9c.jpg?hash=ukF7LqLHab)
32in Long
19in Wide
20in High
Wood: 135,000 BTUs
Coal: 155,000 BTUs
