I was hoping that the bar would be a little stronger and not as prone to spreading apart as much.
Is the replaceable sprocket an improvement over stock?
Only if you have the bar long enough to wear out the original tip while the rest of the bar is still in good condition, and if you can then find a replacement tip, and if you have the time to change the tip yourself, and if the if the difference between the price of the replacement tip and the price of a whole new bar is enough to compensate you for the time you spent hunting for a replacement tip, ordering and installing it.
So... probably not.
The primary benefit of a solid bar is that it's structurally stronger than a laminated bar, so it's less likely to get bent accidentally. The rails may or may not be harder / wear longer. The tip's being a separate component and thus "replaceable" is just inherent to the manufacturing process; it's not feasible to make a solid bar with an integral sprocket tip. Calling it "replaceable" is mostly marketing spin; they rarely get replaced.
The Bar showed up in the mail ... nice piece of equipment.
I thru on a still Stihl rcs chain and the new bar on the Husky 350.... Nice .. I like it!
I checked out what Lowe's was selling the 18" Husky bar for $39 then Tractor supply's Jonsered 18" $44
So $42.50 to door not bad and a better bar so far! Time will tell. I'll let you know, after I get to play with it for a while.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
