I have tried and tried but I cannot get positive pressure through out the whole house. Its in a 2700 sq ft house with a really open floor plan and 9-12 foot ceilings, with about 1/3 of the space on the second floor. The great room is 20x20 in size and 26 feet tall at its highest. Its a new house and pretty tight as I have to be careful when the furnace runs or I get back drafting when I first light the unit up because there is a big cold air return vent on the first floor. (once the doors are closed no problem). The house is also zoned forced air and the air is not balanced very well hence the negative pressure problems when it runs. I try not to use the furnace when burning wood anyway as that is the point of burning wood. (ps we have a CO detector at each bedroom).
Anyway my real point is when the furnace is not running but the fireplace is and is blowing air from outside the home aound the fire box and into the house I can still not get positive pressure. I definately get a convective current to set up inthe great room as the celing fan will spin on its own as the hot air rises...we also get to experience the cool air coming from the floor vents of the HVAC system which I suspect is coming from warm air going in the upstairs vents.
Been back and forth with the HVAC man and he claims have 380cfm of air leakage is common in a house this size...Me and my calking gun are best friends but alas no success. I want to get a blower door test done to check the actual leakage but no one in this part of the country does anything like that...I have looked.
I have been thinking about adding more capacity to the incoming circulating air by adding another duct and fan and then connecting that to the existing line past the original fan but before it enters the fire box jacket..any suggestions?
Most of my home is within 4-5* (68-73*). One exception is my office as it is at the base of the two story foyer. I just hit the house fan (moving around interior air, not adding or subtracting) and bring it on board.
