My 150 y.o. farm house has no basement, only an open crawl space. I recently had all the water pipes moved from snaking a jillion directions under the house so that they are now all above the floor, except for the short main supply line that runs from underground up through the floor. I have super-insulated that one and so far this has solved having to crawl under the house 3 or 4 times every winter to thaw frozen pipes, but both showers and the bathtub have a p-trap in the drain line, located under the floor in the crawl space, since there is no room for a trap above the floor. It got down to 18 degrees last night and one of the shower drains wouldn't flow this morning. It thawed out a couple of hours later, so it was probably just a skim of ice on top of the trapped water, not frozen solid.
I could purchase a can of RV anti-freeze and pour some in the shower and tub drains whenever the temperature is predicted to drop to the low 20s or below, which should keep them from freezing. Is that stuff safe for use with a septic tank? I don't want to introduce anything into the septic system that will kill the bacteria.
Don
Don
