IT IS THE WOOD! If you found your way here researching a new purchase (like me) don't pull the trigger unless you have dry wood. By dry I mean 2+ years C/S/S. I was better off than most newbs this year because I had a couple of cords in the 20% range and I STILL dealt with many frustrating evenings anchored to the stove waiting to be able to shut the door without the fire going out. The moisture meter will help, but nothing short of a multi-year calendar will tell you for sure.
I know this for sure because I came into some 2+ year C/S/S wood that someone wanted to get rid of. The same insert that would not allow me to close the door for 15 or more minutes with splits that measured 20% ran with no more effort than opening the air, opening the door, reloading, closing the door and then coming back in 5 minutes or so to start closing down the air. It ran like an absolute champ with DRY WOOD.
I share this to HAMMER home the point and save a new wood burner some frustration. DON'T BUY THE STOVE IF YOU DON'T HAVE THE WOOD. Wait a year, scrounge like a hoarder (it can be fun), get it split and stacked and THEN get the stove.
