Furnace Cement Odor
milesmoony
44
Olympic Peninsula
Has anyone else experienced this? If so what did you do? I recently painted my glo fire 301 wood stove. Sandblasted it, packed the seams with imperial furnace cement, and 3 coats of stove bright satin black. I fully cured the paint with two raging hot long lasting fires outside before moving the stove back in. All seemed to be well until AFTER a couple weeks of burning. Now every time I build a fire for the first hour or so I get an awful odor coming from the stove - smells like burning plastic. After the fire gets the stove up to temp the smell pretty much goes away. This smells nothing like curing stove paint, the paint is totally cured. I’m positive it’s the furnace cement. Has anyone else had this issue? Only thing I can think to do is take the stove back out and have another glowing hot burn-a-thon. Doesn’t make sense to me though. Any advice appreciated!
milesmoony
44
Olympic Peninsula
Anyone had a similar experience? Thinking I need to take my stove apart and remove all the furnace cement. I’ve been burning the stove everyday for over a month now and the smell is stronger than ever. No problems with the paint, paint is fully cured.
begreen
Mooderator
Staff member
Nov 18, 2005
87,139
South Puget Sound, WA
No, I haven't, though I have never used the Imperial product either. Was any silicone used on the flue collar or stove piping?
firefly123
1
04101
This is an old thread but yes, put stove cement on the flue of my stove after curing it with a few outdoor fires and it continues to stinks for the first 1/2 hour to 45 minutes after lighting it. Starts smelling well before stove is up to temp. I'm fairly certain it is the stove cement. Did you figure your issue out?
milesmoony
44
Olympic Peninsula
Never did, but I am certain it’s the stove cement. Same as you described. I called the manufacturer and they claim there’s no way it’s the cement but I just don’t buy it. It’s very unpleasant, to the point I will either need to chip/wire brush it out or get a new stove
bholler
Chimney sweep
Staff member
Jan 14, 2014
23,847
central pa
I have used lots of furnace cement in lots of applications and never smelled a thing from it
begreen
Mooderator
Staff member
Nov 18, 2005
87,139
I haven't either with Rutland orJotul stove cement. We have had an occasional paint job that has been the source of a smell, even after being baked in. One, many years back was actually sooting up the woman's living room.
bholler
Chimney sweep
Staff member
Jan 14, 2014
23,847
central pa
What paint did you use?
Never mind I read back and saw stove brite.
milesmoony
44
Olympic Peninsula
What brand did you use?
Imperial?
