I have a two story slab on grade total square footage 1900 square feet plus an attached garage. I live in Newfoundland where the winter temperatures can range down to -20C but are normally no lower than -10C. I have a Newmac wood oil combo in my attached garage that heats the house and I am not satisfied at all. The issue with the furnace is where it is located in the garage the only heat you get in the house from it is when the blower is going. Due to the slab on grade my furnace ductwork runs across my ceiling on the bottom level and blows down from the ceiling with the cold air return on the floor and the normal setup for upstairs. Once the fire dies down and the blower kicks out there is no radiant heat going into the house approx. 4 hrs. (12am to 4am) overnight and from 12 pm until we get home from work at 5 pm. Therefore the house cools off and secondary heat ( oil) needs to be used to keep the house warm which is very expensive. Furnace oil is $1.0581 a litre now and we have seen prices much higher than this in the winter. I am planning on keeping the furnace for a couple of years until my oil tank expires and then put in a electric furnace or a few mini splits as a secondary heat. Before the winter comes I am looking at installing a wood stove and chimney in the house to keep the house warm during the night and the day. Due to the cost of the install I have decided to go with a cheaper stove that I may later use in the garage. Two of the stoves that I have narrowed it down to are the Century fw3000 and the Timberwolf 2200. The timberwolf is more efficient at 86% listed vs 77% but the Century has a larger firebox 2.4 or 2.9 not sure vs 1.9 The Century is on sale now for $799 but the blower is optional and the Timberwolf is $1199 with everything included. Does anyone have either one of these? What are your opinions? Thanks!
What part of Newfoundland are you in?
