I installed my garn 1500 january 2014 and used it the rest of the winter. During the spring i shut down the boiler and did my spring/summer maintenance on it, cleaning the flue and checking it over. I found the anode rod to be completely eroded and a bunch of debris from it laying on the bottom. My water samples came back as perfect and so I replaced the rod around october of 2014. When I checked it this past summer I found the rod gone again. Well I just got a e-mail with a technical service bulletin stating they may have a problem with the anode rods. I read through it and it sounds exactly like what has happened with mine. Here is a link to the tsb in case some of you garn owners didn't get it. http://www.garn.com/wp-content/uploads/general/tsb/TSB-AnodeRods.pdf
I am thinking it may be best for me to drain my garn and get all the fluff and chunks of anode rod out of my boiler.
