If anyone is familiar with Garrison wood stoves, they are a terrific little heater - in a relatively small space, this thing heats like crazy.
Problem: In the ceiling of the woodstove there is a 1/4" thinck piece of steel at an angle to maximize heat distribution and re-burn some of the smoke, etc. It's jjust part of the design.
However as I've been burning this winter the baffle has warped and dipped downward in the middle. this affects the stove in a few ways: it limits the amount of wood I can load, it exposes the flue opening to spark and flame which HAS to be dangerous, and affects the way the dampers let in oxygen.
My questions are these:
1. Is thre baffle easy to remove, flatten, and reinstall.
2. Can i just remove and flip it upside down so it warps upwards thereby prolonging the time until I need to repeat the process
3. is this warping dangerous/is there a way to prevent?
Please answer IF you have experience with Garrisons. They are REALLY different than your average stove and i cant afford guesses!
thanks
jimmy in Minnie
1976 garrison 2
thanks
jimmy in Minnie
1976 garrison 2
